Lifter Replacement Question
If you read the OP's post, and the post you just quoted, he asked if the lifters could be removed that way. I assume he didn't want to replace the pushrods. I didn't recommend doing it that way, but I definitely think replacing the cheap OEM lifters is a great idea. My '07 Twin Cam had a lifter bleeding down over night in less than 10,000 miles and my '17 RGS had the same issue. It isn't uncommon for the rollers to fail on the new pushrods and after removing the stock cams there is often "frosting" on the cam lobe and lifter roller. It's a failure waiting to happen and I don't want to have problems 2,000 miles from home!
I did read his quote, I was referring to your quote, about tearing into the camchest for a simple lifter replacement. Harley has also had a couple of revisions, if not suppliers of lifters since 2007. Anything mechanical can fail at some time or another . It doesn't mean that every Harley motor is going to check out with a lifter issue. The majority of them will be just fine. Don't worry....be happy!
mjwebb (05-04-2021)
I am not sure what component you speak of here.... " It isn't uncommon for the rollers to fail on the new pushrods" Also. "frosting" on the cam lobes does not mean the parts are ready to grenade. It is considered acceptable. Grooves, marring, metal transfer and galling would be considered UN acceptable and would need to be replaced.
Well , I doubt you could get the cams out without unloading the pressure on the lifters from the valve springs anyway. And if you could, you might damage something else in the process. But I don't believe there is any reason to open the cam chest if you aren't going to upgrade the cam and bearing while there. And then, you would need a tuner too.
On earlier single cam engines, Shovelhead and EVO, the pinion shaft / gear prevented the lifters from being removed from the bottom. I've never tried it on a Twin cam, but I suspect it is similar too. And either way, you will need to unload the pressure on the lifters which means pulling the rocker boxes or cutting the pushrods form the bottom and replacing with the quick install type adjustable pushrods.
At 10k miles, I wouldn't be too concerned about a lifter failing, I know of people with 20k plus with no problems on a stock cam. As mentioned above, if it starts to clack for a moment when started cold, it's time to look at that and replace lifters after a good diagnosis. And then, use the S&S or Hylift US made lifters.
Paul
Paul
Hey guys, my 2020 Sport Glide has 10,000 miles. I plan on increasing my rate of accruing miles after retiring next summer. As a preventative maintenance measure, I will be replacing lifters with "premium" versions after this riding season. I would like to drop the lifters out of the cam chest, avoiding removal of the lower tappet covers and push rods. Is this possible or will the push rods need to be cut or removed from rocker box covers? I realize the cam plate and cam need to be removed for this work.
I just checked and the M8s use the same "C" lifters that the later Twin Cams used. Many believe these lifters to be a weak spot...
In my Twin Cams, I wouldn't make a trip into the cam chest just to replace those lifters if they weren't making noise. If I went into the cam chest for any other reason, both the lifters and inner cam bearings were replaced, but I never made the trip into the cam chest just for the lifters as preventative maintenance ..
I would suggest the same for an M8...
As a side thought, whenever I replaced the lifters, I never replace them with another HD lifter. I use the Johnson Hylift lifters from WFO Larry...
If there is no issue with the lifters better to just leave them alone I have had replaced with SE ones and went back to OE due to excessive noise. New M8 filter and HD oil works very good with my M8 IMO. My lifters were noisy before again IMO because I was using Castrol V Twin synthetic switched to HD oil and M8 filter it runs great.
steelpony16
08-07-2013 06:25 AM
