Checking for manifold leak
08-06-2022, 04:31 PM
What would be a good way to check for a manifold leak on a Milwaukee 8 ?
08-06-2022, 05:53 PM
Spray some Gumout carb cleaner on the flanges at each head ( just make sure the engine isn’t super hot, for obvious reasons). If the RPM changes, you’ve got a leak. If it does not affect RPM, it can be assumed there is no leakage.
08-06-2022, 06:03 PM
You can also use a propane torch, unlit, and direct the gas at the manifold seals. A change in RPM indicates a leak.
martin10
2018+ Softail Models
01-30-2022 05:59 PM
e_minor_pentatonic
08-24-2020 03:51 PM
skinman13
03-25-2018 01:31 PM
texashillcountry
EVO
29
05-12-2016 12:10 PM
94 lr
07-13-2013 11:17 AM
