Metallic noise when accelerating from low RPM
Old Feb 20, 2026 | 07:45 AM
slonez_sg's Avatar
slonez_sg
Default Metallic noise when accelerating from low RPM
The 114 on my Breakout has been fitted with RS468, fuel moto pushrods, Johnson lifters and Thundermax. I have this setup for about 1000km already.
I realized that if I whack open the throttle from low rpm 2000rpm on 6th gear, there is a metallic noise coming from the valvetrain. No such issue if I whack open at 2600-2700rpm.
Is this normal or there is an issue with the pushrods adjustment?
Old Feb 20, 2026 | 07:53 AM
buell95's Avatar
buell95
Pinging my guess, Thats seems pretty low rpms for sixth gear.
Old Feb 20, 2026 | 08:09 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Whacking open the throttle in 6th gear at 2,000 RPM.
Too much throttle at low RPM=detonation.
This type of operation is not good for an engine.
Old Feb 20, 2026 | 08:10 AM
Schex's Avatar
Schex
"Doc, it hurt when I do this"
Doc- "well don't do that"
A good rule of thumb is to try to keep r's a minimum of 2500.
2000 is probably ok putting around in 1st or 2nd gear
Old Feb 20, 2026 | 08:13 AM
slonez_sg's Avatar
slonez_sg
The bike has good torque so pulling from 2000rpm still feels good except for the metallic noise.
slonez_sg's Avatar
slonez_sg
Noted.
Old Feb 20, 2026 | 08:14 AM
slonez_sg's Avatar
slonez_sg
You are abusing the engine.
Noted!
Old Feb 20, 2026 | 11:50 AM
rigidthumper's Avatar
rigidthumper
Thundermax software has a "how to" about timing vs detonation adjustments. Using map #480? Tmax Troubleshooting > Ping Detection > Timing vs TPS
Old Feb 20, 2026 | 04:01 PM
Bemo56's Avatar
Bemo56
Bad gas?
Old Feb 20, 2026 | 06:49 PM
slonez_sg's Avatar
slonez_sg
Originally Posted by Bemo56
Bad gas?
Will try again with new gas.
