FS: Cheap, Easy Upgrade From Stock
Selling a set of Polk Audio MM651 speakers and a Rockford Fosgate PBR300x2 amp. This was my first upgrade equipment and I bought it used from a forum member. I used these with my HK head unit (2012 Ultra) and it was a great upgrade for what I spent. Big difference in sound. Simple to install and set up. Amp easily fits on top of head unit.
So, now with that said, I quickly got the bug and began reading everything I could read here and replaced the amp a few months ago when I added lowers and the speakers are being replaced this week finally. I know these are not the top of the wish list and if you've done any reading here you may want to go bigger and better. BUT if you want a cheap upgrade from stock, without replacing your stock head unit or you have stock speakers that are damaged this may fit the bill for you.
I paid $150 for the amp and speakers so I'll let them go for $75 plus shipping. You will need power (with a fuse) and negative cables for the amp, some 6.5 adapters for the fairing and some speaker wire. Other than that everything works and is undamaged.
I'm at work but will put some pics up later tonight or tomorrow.
