Oil Archive (no new posts) An archive of oil related questions and comments.
Oil blow-by cure.
Old Nov 28, 2009 | 12:20 PM
eharms325's Avatar
eharms325
Default Oil blow-by cure.
If you are having issues of blow-by oil in your air filter, here is a way to end it. The rocker support plate has two small holes for oil return under breather plate. Remove support plate and drill out holes to 1/8" and put back together. A instructor at MMI told me this, and did it to a friends bike who had bad blow-by and it took care of it.
I'll post pics as soon as I can figure out how.
Eric
Old Nov 28, 2009 | 08:48 PM
dawg's Avatar
dawg
This is taken from the Doherty Mystfree breather system. They advise to use a #43 drill bit (close to 1/8) and drill out the rocker supports. I do it to all the bikes I go into. HERE's a pic
Old Nov 28, 2009 | 09:12 PM
2003Springer's Avatar
2003Springer
Thanks both you guys for the post..
Old Nov 29, 2009 | 10:58 AM
rbabos's Avatar
rbabos
These holes are not only drainbacks but the source of air exiting the engine while breathing. A slight increase in dia will give benifit, but go too big the first few revolutions at startup will be quite aggressive to the umbrella valves. Once running the outflow is low, but increases with high rpm loads. The .089 is a good compromise for both operations in my view.
Ron
Old Jul 17, 2012 | 01:45 PM
SC-Longhair's Avatar
SC-Longhair
Interesting. Would head removal be necessary to perform this?
chevdude
Engine Mechanical Topics
Oct 11, 2014 07:27 PM
SURFOR Chop
Exhaust System Topics
May 28, 2013 10:40 AM
Mudflat194
May 8, 2011 06:37 PM
paulies 07
Dec 21, 2010 01:02 PM
mplecha
Jul 22, 2009 12:18 PM
