Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil 1 primary.......
Old 03-12-2019, 06:32 AM
USMC0352's Avatar
USMC0352
USMC0352 is offline
Default Mobil 1 primary.......
I've been using Mobil 1 v-twin 20w 50 oil as my engine oil with great results.....I've been reading
that it can be used as a primary oil......can I?
Any input would be great
Thanks in advance.
John
Old 03-12-2019, 06:43 AM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is online now
Received 3,995 Likes on 2,199 Posts
You can use it in all three holes, but there are better alternatives. I use Formula+ in the transmission and primary. Harley just came out with Heavy Synthetic Gear Oil. I'm thinking about giving it a try next oil change.
https://www.harley-davidson.com/stor...-gear-oil#tabs
Old 03-12-2019, 06:57 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,602 Likes on 3,847 Posts
Harley in the last few years went back to Formula + in transmission and primary. You do not want high detergent additives in oils in boxes without a filter. Not an oil thread comment. An engineering one.
Old 03-12-2019, 06:59 AM
Cossack84's Avatar
Cossack84
Cossack84 is offline
I'm inclined to go with gear oil next change. But yep you can sure use Mobil in there as well.
packmen21's Avatar
packmen21
packmen21 is offline
+1
Old 03-12-2019, 07:45 AM
beisbol mike's Avatar
beisbol mike
beisbol mike is offline
Mobil 1 4T is better suited if you read their literature
The following 3 users liked this post by beisbol mike:
71on72 (04-14-2019), DeputyDawg (03-01-2020), MotoJockey (02-14-2023)
Old 03-12-2019, 07:50 AM
71on72's Avatar
71on72
71on72 is offline
Received 16,760 Likes on 8,685 Posts
Another oil thread so I’ll chime in.
I use Mobil 4T synthetic because it is JASO approved for motorcycles that have 1 chamber for engine, transmission, and wet plate clutches. Available at Walmart and auto parts chains. Used it in Yamaha motocross bikes for years.
Mobil V-twin in engine.
https://mobiloil.com/en/motor-oils/m...motorcycle-oil
Old 03-12-2019, 08:00 AM
Inop's Avatar
Inop
Inop is offline
Ive been using Mobil 1 20w 50 in my primary for a while now.
Old 03-12-2019, 08:01 AM
craigffb's Avatar
craigffb
craigffb is offline
Mobil 1 4T in the primary for me as well.
Old 03-12-2019, 08:44 AM
Mertoid's Avatar
Mertoid
Mertoid is offline
Formula + in the primary and transmission for 107,000 miles and zero problems.
There might be better lubricants out there for the purpose but I'm sticking with what's been working. If it ain't broke, I don't have to fix it...
Quick Reply: Mobil 1 primary.......
