Primary oil question
Just changed the starter on a 1997 electra glide. Removed the primary cover, put it back, flowed the torque sequence. Now dripping oil from bottom of derby cover. Replaced gasket. Question is, If the primary is over filled, will it drip put of the derby cover? Any help is greatly appreciated.
Just kind of odd that I never touched the derby cover. It started leaking after adding oil back into the primary. I'm going to get a new cover, hopefully it solves the problem.
How did you add and set the fluid to the proper level without removing the derby cover??
Why didn`t you remove the derby cover and service the primary the correct way?
The derby cover is the cover that is removed to adjust the clutch, and to service the primary with oil.
No other cover is considered the right cover to remove to install lubricant.
Try opening up an owners manual or service manual, and you will see how to properly service the primary.
You are guessing what the lube level is in your primary...
Why not just do it the correct way?
ElectraJim (08-09-2021)
I opened the chain guide cover to refill the fluid. I don't think there is any reason to be chastise about how I filled the primary. I thought this forum was to help.
The following 2 users liked this post by strych9:
JimL_15 Electra Glide (08-10-2021),
Sleepintiger (09-05-2021)
