Oil on fins
Oil on fins
I have an o4 Road Glide with a stock motor. After a 30 minute ride, I am seeing oil on the fins of the rear cylinder starting at about the same level as the exhaust pipe. Any thoughts? Head gasket?
Also, any tricks to effectively cleaning the oil with out damaging the poloshed aluminum?
Last edited by No Buffeting; 08-25-2012 at 10:04 PM. Reason: New to this sight and like a newbee, I likely posted in the wrong section.
Could be head gasket...could be exhaust gasket+bad rings...hard to tell. Can you upload some pix so we have a visual???
Thanks for the input all - took me a while see more oil after cleaning everything. After looking, i believe the oil is coming from the rocker box cover and blowing onto the fins.
