Connecting Devices Directly to the Battery
I could have sworn I saw a previous post regarding the best path to route wires down the left side of the bike and connect directly to the battery. But for the life of me I can't find it.....
I need to route wires from the handlebars down the left side of the bike to the battery. Does anybody have any suggestions on the best way to route the wires?
Again, sorry if this is a repeat but I couldn't find the info.
Thanks!
Thanks!
Lower cowling/fairing whatever you want to call it......the plastic part inside the crash bar. You can open it up a bit by removing a few screws (no need to remove it fully) and route wires inside it from the battery. That's what I did for my GPS power and you can't see the wires at all. I also hid the Garmin power brick thing in there.
It's a good solution if you don't want to power lots of high current stuff for sure.
I loosened up the screws for the plastic lower fairing and routed my GPS wires inside it at the top and out at the bottom. It hides the wiring completely.
If you don’t mind me asking where did you get the harness from (a link would be helpful), where did you source your switched power feed from for your Innovv Power Hub (is that part of the wiring harness) and where have you located the Power Hub itself under your seat? Many thanks John.
DavesEagle (02-04-2022)
pghguitar
Electrical/Lighting/Alarm
05-19-2018 10:26 AM
benningtonr
2014-2023 Touring Models
11
03-04-2017 07:10 PM
