First addon?
That Adventure Jiffy Stand is pretty interesting.
From HD - https://www.harley-davidson.com/us/e...and/p/50000264
• For models equipped with Adaptive Ride Height
• 60% larger footprint compared to the Original Equipment jiffy stand for more-secure support when parking the motorcycle on soft ground
• Does not alter the height of the jiffy stand to maintain original lean of bike when parked
• Factory designed for easy installation, an ideal fit and maximum durability
• Does not change lean angle when motorcycle is cornering
The first two seem to be the biggest changes as I have read complaints on the OEM jiffy stand when using ADH.
D4s for the front - on the Denali specific mount.
T3s at the back for run/brake/turn.
SoundBomb horn on - on the Denali specific mount.
All powered by a Hex Innovations ezCAN controller specific for the PanAmerica. All plug and play, all good!
Just placed my order
Denali Hi-Viz Turn Signals
Actually after reminding myself how the front turn signals are connected it is even easier….
This part Connector allows for the lights to be connected in conjunction with the OEM turn signals.
