124 & 128 Bolt-In Big Bore Kit for M8
Bolt-in power for your Milwaukee Eight engines, S&S 124 and 128 kits are simple and effective means of big gains for your big engine.
Each kit is designed specifically to work with the 107 or 114 engine to deliver reliable power with little more work required other than swapping out the pistons and cylinders. Otherwise, everything you need is included in the kit along with a set of well-written instructions. About the only thing youll need to do is adjust fuel delivery for the new configuration, break it in correctly and youll be smiling whenever you open up the throttle. We have a variety of fuel tuners thatll do the job on our website here. And since youd already be halfway into the engine, you might as well have an oil change kit on hand as well.
Theres no replacement for displacement! Take your 107 to a 124 or your 114 to a 128 big bore, in the simplest way possible with a bolt-in big bore kit from S&S!
These kits are available with all-black cylinders or black cylinders with highlighted fins. To order yours, simply call 888.575.6570, send us a PM here or email forums@partsgiant.com along with the model and year of your M8 and well get back to you right away.
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
fuelmoto
Fuel Moto / Jackpot Mufflers
04-04-2019 09:31 AM
