Ironhead A place to talk about Ironheads.
Big Bore Kit
Old Jun 18, 2006 | 10:34 PM
SKJOLD's Avatar
SKJOLD
Default Big Bore Kit
Anyone hear of any big-bore kits that can bring an Ironhead bore to 3.5 inches or more?
Old May 10, 2020 | 07:45 AM
dracer's Avatar
dracer
you would want to look into the S&S catalog for upgrades like what you want. sscycle.com
Old May 10, 2020 | 08:16 AM
Y2K's Avatar
Y2K
Years ago I had an Iron taken out to 86" via a Truett & Osborn stroker crank and an Axtell big bore kit,I don't recall the actual bore size.
It was a fast bike,high compression domed pistons with over sized valves and extensive porting done at http://www.baisley.com/
The machine shop welded in the bolt holes for the jugs and drilled new ones in a bigger pattern so it was pretty big.
They flycut the pistons for valve relief and also did some clearance work on the cases for the crank as well as polished the insides for better oil return and windage.
https://www.axtellsales.com/home.php?cat=
Old May 10, 2020 | 03:12 PM
nibroc's Avatar
nibroc
my Dytch jugs are 4 1/4 + .040 over on my 59 XLCH w/S&S btm. end
missedem
Sep 3, 2020 08:06 AM
scooty
Feb 9, 2011 10:18 AM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
Oct 20, 2010 07:25 PM
bigmikaele
Jan 10, 2009 01:28 PM
hotrod351
EVO
Oct 12, 2008 09:46 AM
