Ironhead A place to talk about Ironheads.
New headache
Old Mar 24, 2010 | 05:28 PM
EvilWayz's Avatar
EvilWayz
Default New headache
My rear brake won't bleed, and there is oil just pouring out of the right side of the primary, right near the pump.
I assume a gasket will fix the oil leak, but the rear brake, well the piston is mounted upside down, with the bleed facing down, I don't know that it makes any difference but I don't know how the air is supposed to get out that way.
Thoughts?
Old Mar 24, 2010 | 05:57 PM
IronMick's Avatar
IronMick
Best way to bleed brakes, especially rear brakes where the run is horizontal rather than vertical, is to use a 60 ml irrigation syringe, available from drug stores or medical supply for about $2. Fill the syringe, and force the fluid from the caliper to the master cylinder.
Empty the master cylinder first; let the bubbles settle up out of the fluid in the syringe; use undersize clear tubing between syringe and nipple, 6" length is plenty; undersize so that it is a very very very tight fit on the nipple so no air leak [i have to force it on with needle nose pliers]; have master cyl lid loosely on master cyl else fluid will shoot 10' across the room; loosen the nipple, force fluid thru.
First time may not work so well; but after you get the hang of it this is the only way to bleed brakes IMO.
Old Mar 24, 2010 | 06:31 PM
09DynaMan's Avatar
09DynaMan
The caliper cannot be bled front to back while it is upside down.
You have to take it off, turn it the right way up, and slide something between the pads in lieu of the rotor.
Then you can bleed as normal.
I have never needed to use any of the backfill methods.
I know many struggle with brake bleeding, and, to me, most methods are born out of that dynamic.
To push the fluid front the back to the front also means you are pushing all the gunk towards the m/cyl, and those oh so important little holes that live there, and that block all too easily.
Do you actually mean that your cam cover is leaking???????
Old Mar 25, 2010 | 06:13 AM
EvilWayz's Avatar
EvilWayz
I though the oil was coming out of the scavenger pump, but on closer inspection, its coming our of the right side of the chaincase, hitting the frame an then dripping down the pipes. i would assume that's the cam seals, but i don't know that much about these engines yet.
Old Mar 25, 2010 | 06:38 AM
Neil74's Avatar
Neil74
Is it leaking from primary cover side or rear chain cover side? Are you losing oil from your oil bag or from the transmission? Primary cover side I'd suspect a gasket if you've had the cover off recently. If it's coming from the transmission sprocket cover, take the cover off and make sure the oil lines from pump haven't been worn thru by the chain, You can also check if its coming from the trans seal behind the sprocket. If it's running out while running I'd suspect a bad hose from chain contact.
Old Mar 25, 2010 | 07:28 AM
IronMick's Avatar
IronMick
Originally Posted by EvilWayz
... there is oil just pouring out of the right side of the primary, right near the pump.
I assume a gasket will fix the oil leak, ...
The "primary" refers to the lower left side of the engine which contains the primary chain, also called the front chain or the drive chain; sometimes "primary" is used just to refer to the cover.
The lower right side is the gearcase, often referred to as the cam chest as it contains the cams. The oil pump is on the front , just below the gearcase cover, also referred to as the cam cover.
So, exactly where is this oil pouring out? Can you post a pic? Oil would not usually "pour" out unless there is a hole.
You need to have both a factory service manual 99484-78 and a factory parts catalog 99451-78B in your hands before opening up any of these engine areas; and so that you can understand things better.
Old Mar 25, 2010 | 07:44 AM
09DynaMan's Avatar
09DynaMan
This is clearly so true for you.
A great deal of the issue is that I/we have no idea as to what you are talking about, as you have no idea what you are talking about.
The factory manual is exactly what you need, and a parts book for any bike you personally own is always very useful.
There are quite a few possibilities for leaks around that area.
Old Mar 25, 2010 | 07:56 AM
EvilWayz's Avatar
EvilWayz
Well my service manual is with my mechanic, who is in Greece on his honeymoon. The oil is dripping from inside thur the gearcase cover about even with the scavenger pump. When I bought this pos in november, I was told that the engine was recently rebuilt. I assume since there's a pretty decent oil leak it wasn't done right. the oil is not technically pissing, it's not under pressure, but it is dripping fairly quickly. I suppose i can get a online copy of both manuals since my paper ones are currently unavailable and print out the pages i need.
Old Mar 25, 2010 | 09:51 AM
IronMick's Avatar
IronMick
You are still not describing the location of that oil leak in a way that we can understand. It does not sound like a simple gasket leak. Clean up the leak area thoroughly, take a pic, and post it here. If you do not have a digital camera then get one as it is another essential tool for using these forums.
Old May 17, 2020 | 01:08 AM
Katherine Wright's Avatar
Katherine Wright
Stage I
Default Flyweights
Thoughts?
you have to get it lost and swing the bleeder upright..or you can try attaching a hose and try bleeding it that way however I haven't had any luck doing it that way. ROLL BRAKE HOUSING upP!!!!.just make sure that bleeder isn't stopped up.also one more thing,,,
get you a extra set of fly weights and put them in ur tool bag. If you ride aggressive?? You'll NEED EM!! And if you want I can show you how to dynamic time the ignition.also there's static timing. And the center bolt that holds everything together you must make sure it's not runnin eccetric!! If not it will never be exactly right. Still run just not like mine use to.Allot of time when they start popping,and. It's hell to crank one of the mechanical advance weights Will have slung a spring off one side,,,,usually rear cyl spring, then sometimes pooting and poppin one lunging check mechanical advance.however if you do get it mechanically sound it will reward you with a beautiful harmony.also about oil, thosehad automatic chain oiler's,
some ******** at the dealer would try to bypass!! Findu a diagram.if it's ur oiler line blocked off it will slung oil from every office.
if you done want the auto oiler.U must put a filter on the line NOT BLOCK!! Why???
it's the crank case VENT IT is supposed to have a lol spray of oil. I hope I have shed some light for ya. I'm late husband.( putting tire) on my heritage and let lift down on my screen!! Just don't give up!! There's a lot of ******** out there thatwill tell you all kinds of BULLSHIT LIKE 50 at oil for tranny!!!😳😳
PUT EOTHER 80W90 ER 85/140.PLUS A LIL
STP blue bottle. Shift like butter.
Holler if I need clutch help.
Ron harrison
