View Poll Results: Would you install a big bore kit or get other mods?
Install the big bore kit
84.44%
Don't waste the money, get other mods
15.56%
Voters: 45. You may not vote on this poll
big bore kit
Old Jan 9, 2009 | 07:47 PM
bigmikaele's Avatar
bigmikaele
Default big bore kit
I am considering putting a big bore kit on my SB, but have heard mixed opinions from folks that have had it done. For those that have had it done to their bike would you recommend it or recommend using the money for other mods?
thanks.
Old Jan 9, 2009 | 07:51 PM
benwiggin2's Avatar
benwiggin2
I want one. 103.
Old Jan 9, 2009 | 08:23 PM
archergodwin's Avatar
archergodwin
There are other mods I would do to the engine before the big bore, in prep for the big bore. Such as the timken bearing upgrade and welding and rebalancing the crank.
... but the big bore kit is in the list of mods I'd like to do... someday... maybe.
Old Jan 9, 2009 | 08:40 PM
TexasSnake's Avatar
TexasSnake
Default mmmmmm...big bore.
No question. I been drooling over ZIPPER'S SLEEPER 103" KIT for quite a while now.
Old Jan 9, 2009 | 09:31 PM
Azgunner's Avatar
Azgunner
I have a good running 95". There is nothing like power on demand. I prefer go to show.
Old Jan 9, 2009 | 10:06 PM
Cornhusker's Avatar
Cornhusker
I didn't vote in your poll. I don't think it's a waste of money to do the 103 build, but I believe I would do the cosmetic mods to make you bike yours before I would do the build. While I'm glad I did the build, I had more fun doing cosmetic, personal mods.
Old Jan 9, 2009 | 10:11 PM
speedjunkie's Avatar
speedjunkie
Are you happy with the way it runs now? Does it have enough power for you now? Is the WOW or SMILE factor high enough for you? If the answer is no, then go for it. Or start small and drop in a Woods 6 cam and see if that's enough. With a Woods 6 you can always reuse the cam and go 103 and heads later. Just my opinion.
Mike
Old Jan 9, 2009 | 11:08 PM
chad peterson's Avatar
chad peterson
Good advice if money is tight & ya can't do it all at once. You'll get sufficient gains by adding the woods tw6-6 cams & can have a good set of heads built in the mean time & do the big bore when your all saved up! Doin just big bore & no cams or headwork I think sucks!
luckyB's Avatar
luckyB
The big bore kit is worth it in my book. I love the extra torque.
Old Jan 9, 2009 | 11:20 PM
SC-Longhair's Avatar
SC-Longhair
I actually appreciate you bringing that up because I had always heard the term "timken" but never knew what it was. I found a very good explanation HERE
From that video, I found out the oem bearings are from a company called Ina. Where I live, Ina is a major employer having 3 or 4 plants throughout the town . Who knew.
