Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Bike will not go into first gear
Old 08-30-2015, 01:00 PM
Mikey_P's Avatar
Mikey_P
Mikey_P is offline
Default Bike will not go into first gear
Went to go riding today and my bike will not go into first. First time riding since I got back from Sturgis. No shifting issues before except the shift arm coming off where it exits the transmission. It acts like there is no first gear. The shift lever goes down like normal but stays in neutral. Any suggestions?
Old 08-30-2015, 03:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,532 Likes on 4,631 Posts
duh double post...Sorry
Old 08-30-2015, 03:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by Mikey_P
Any suggestions?
You might tell us the model and year...
Old 08-30-2015, 04:43 PM
HDmikie's Avatar
HDmikie
HDmikie is offline
Subscribed.
Old 08-30-2015, 06:01 PM
Mikey_P's Avatar
Mikey_P
Mikey_P is offline
09 road king classic
Old 08-30-2015, 09:12 PM
103inches's Avatar
103inches
103inches is offline
Wondering if the foot shift lever returns to it's normal position when you (attempt) to click down into 1st. If the foot shifter doesn't spring back, then I'm thinking...The shift arm at the tranny can/will strip.
Old 08-31-2015, 05:09 AM
Mikey_P's Avatar
Mikey_P
Mikey_P is offline
Comes right back like there was nothing wrong. It will shift to the higher gears just fine.
Old 08-31-2015, 10:24 AM
HotRod9mm's Avatar
HotRod9mm
HotRod9mm is offline
....... except the shift arm coming off where it exits the transmission....... Any suggestions?
Double check the arm and make sure it did not come loose again, seen it happen.
Old 08-31-2015, 11:41 AM
Mikey_P's Avatar
Mikey_P
Mikey_P is offline
Thanks for the suggestions, I found the problem and now feel like a dumbass. When I replaced the lever I used a bolt that was a 1/4" longer than the one that came with the lever. That little bit of bolt sticking out below the lever was contacting something below and not letting the lever move down enough.
Old 09-03-2015, 09:50 AM
djl's Avatar
djl
djl is offline
Received 2,051 Likes on 1,510 Posts
Isn't that an amazing feeling? In the same instant that you find the problem you feel stupid because it was self inflicted (especially if you have exposed yourself by posting the problem on a forum) but also feel the rush of relief knowing that there is no repair or cost required? Kudos for manning up and joining the club; we have all experienced that same feeling. You are in good company!
Dhillon
07-12-2019 10:38 PM
Gasolinegeorge
08-29-2017 07:28 PM
oldcorps116
EVO
05-19-2013 02:10 PM
Ludeykrus
Ironhead
01-04-2009 03:28 PM
Loch
04-25-2006 12:44 PM
Quick Reply: Bike will not go into first gear
