2009 ultra noise in neutral with clutch pulled
The noise is only in neutral with the clutch pulled. Happens more when bike is leaned to the right. Noise almost sounds like the starter engages to the ring gear but that is not happening. One intresting find is the clutch push rod is blue on both ends. Looks like heat damage. Unknown how old this damage is. I highly think it is not normal. Could not find any damage inside the primary other than the push rod. Thanks
Long lonesome highwayman
02-23-2019 03:00 PM
