Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Shifts without pulling the lever? Normal?
Old 06-24-2017, 10:51 AM
Chris Scott's Avatar
Chris Scott
Chris Scott is offline
Stage II
Default Shifts without pulling the lever? Normal?
Hi, new here and new to working on my 12 switchback fld, I put 16" bars on and now in trying to get the clutch right, and for some reason I just happened to downshift without pulling the lever in, I've pulled the primary cover of and when I do pull the lever in it does disengage. My ? Is have I done something wrong or could it have always been this way and I didn't notice it? So in short, is my bike suppose to be able to shift without pulling the clutch lever in?? Thanks
Old 06-24-2017, 05:30 PM
dawg's Avatar
dawg
dawg is offline
Received 2,965 Likes on 1,715 Posts
Do you mean able to shift into gear while not running or while running? When not running, the gear shifter can be put into gear without pulling the clutch in. When running, you could technically shift without the clutch if you were to be at the right speed for the shift (although not advisable).
Old 06-24-2017, 10:31 PM
Chris Scott
Stage II
Thanks for the reply, I'm talking about while the bike is off. If it shifts with the bike off I've never noticed it before so it threw me off, thanks for the info dawg!!
Old 06-25-2017, 06:41 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You were lucky that the gears inside the trans were aligned just right. Nothing to worry about! If you sit on your bike and change gear, especially if you rock the bike back and forth a little, you can probably work your way through all the gears and back again. Just be sure to engage neutral or hold the clutch in if you start the engine!
DreadShoes
Harley-Davidson Street
06-07-2019 01:03 PM
bballkking1
10-04-2015 01:26 PM
2015 Harley Davidson Street Bob Guy
05-22-2015 06:54 AM
Cycopath
05-15-2010 06:41 PM
sdroadglide
09-07-2008 06:05 PM
Quick Reply: Shifts without pulling the lever? Normal?
