Changing to chrome inner primary
OK, so I watched the videos, I work with tools for 22 years, I LOVE working on bikes, no matter how HARD, I'm confident on this task, I plan on putting in the baker compensator while in there, and the M6 primary chain adjuster, my question is, I have a 2008 rocker c, 3k miles, but that bearing, on opposite side of tensioner of inner primary, I see you have to pry out oil seal, well I'm getting all new so I will be installing
, ok heres the only question, to install that bearing, hand fitted? need a tool? also does anyone know the Timken replacement, I feel in love with the quality of there bearings, and Harley's, not so much, re- did all my wheel hubs to double row bearings, and what a difference, between the two....any other pointers, obviously all new seal, o-rings, getting the Cometic primary kit, also those 5 harley bolts that hole inner primary to engine, as the red rubber looked sandwiched in videos I saw, don't want any leaks here
....Upgrading started with the Baker, I did a Hillside 107" build, and the clunking driving me nuts, besides I read on the spring problems w/harley compensator, so I figured, why not get the baker, hell do it right? winter deal.....
and with what I listed is it worth the 1300k$$ to do, I have just over 3k miles...I am going to do M6 tho, no matter what....
ill try, do you have dimensions? My indy will press bearing no problem? But yea if you shoot ma a size, ill be good to go...love your products....
scottdoege
10-23-2011 08:48 AM
