Checking Trans fluid question
What year and model is your bike ?????
The reason I ask ,, earlier models your screwed the trans dipstick in, till just touching the oring for oil level check ...
Later models , you do as in the video, (not screwed in, just touching the threads )....
When the change over happened ,, many thought they were over full checking their new later model bikes without looking at changes in their new owners/service manual...
I nearly got caught out , as I had a 2009 electra glide at the time, (screw into to check tran level),, and then bought a 2015 street glide, (not screw in to check tran level).....
Tranny fluid level does not make any difference whether hot or cold.. Engine does.. If you are worried about the leakage issues. do it at the same temp.
