Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
5 speed evo over drive?
Old 07-17-2019, 04:25 AM
Bearlike's Avatar
Bearlike
Bearlike is offline
Stage III
Default 5 speed evo over drive?
Hello, is there such a beast as a 5 speed over drive kit for an Evo gearbox?
I don't want to use a 6 speed kit, as my Pan head (look a like) kick start kit is designed only for a 5 speed box (longer main shaft).
I suppose I could use a 6 speed kit (which I have), if there were a 6 speed main shaft available for the Pan kicker kit. Only wish I knew who made it
So there we go, two questions in one
Old 07-17-2019, 07:41 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,529 Likes on 4,630 Posts
Well,if you are staying with a 5 speed, why not just change either the primary gearing or secondary drive gearing?
5 speed transmissions are all direct drive 5th gear, no overdrive.
Old 07-17-2019, 08:30 AM
bustert's Avatar
bustert
bustert is offline
https://www.twistgear.net/page%20html/twistgear.html
i run the sportgear with int'l gearing on my 01 sport, a real hoot, even surprised some rice
Old 07-17-2019, 08:38 AM
Bearlike's Avatar
Bearlike
Bearlike is offline
Stage III
Hi, I did think about that, but something tells me it's just not the same thing. The gap between 4th and 5th will be further apart, when compared with a proper overdrive. Maybe.
I was hoping an after market manufacturer would have make them.
Of course the obvious thing to do is to use the 6 speed overdrive, sell the 5 speed kicker, and buy a kicker for a six speed.
I was trying to keep the cost down but, oh well.
Old 07-17-2019, 12:26 PM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
You could get a 65T rear pulley (or a larger front pulley), but then all your ratios would be higher. That's what I did to my 94. I've got a 32T front and 65T rear from a mid 90's Softail. Bolted right up and already set for the 1.5" wide belt. Now I spin 2950 rpm at 75.
Old 07-17-2019, 07:08 PM
bustert's Avatar
bustert
bustert is offline
on the sport, 1>4 is geared down and 5th is 1:1
i went with a 55 on the back and stock front which i believe is a 29
with the 55, i get a 500 rpm drop in 5th.
do not think it will fly, even with the 55 on the back it performs better than stock, when i drop out of 3rd, no speedo left to count clicks.
i turn about 2.5k at 60mph.
http://www.twistgear.net/page%20html/sportgear.html
i know it will do 140 but gets squirrley after that. big hold back is the carb
it will pull 60 in 1st and pull the wheel up on a slam shift to second.
Old 07-17-2019, 09:13 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,300 Likes on 3,656 Posts
Din't know if a kicker can be added but..
https://www.jimsusa.com/transmissions.php
Jims Fat 5 overdrive.
Old 07-18-2019, 02:37 PM
Bearlike's Avatar
Bearlike
Bearlike is offline
Stage III
Since posting I've found an after market website with some interesting info.
It mentions other manufactures use screw on tips to lengthen existing main shafts, and the way they always snap off. Oh, here we go again
Diving into the garage to take a close look at the main shaft, what a disappointment; and I thought it was one special shaft.
So I'll be using my 6 speed overdrive, and keep my eyes open for a new kicker.
Thnks for the help guys.
Old 07-19-2019, 07:41 AM
bustert's Avatar
bustert
bustert is offline
screw on tips, that just doesn't even sound right.
Old 07-19-2019, 01:35 PM
djl's Avatar
djl
djl is offline
Received 2,049 Likes on 1,509 Posts
Running the Twist Gear in a 2002 FLHT with a built motor; the increased gap between 4th and 5th is not an issue. Shifting at that rate of speed, the gap won't even register. The neat thing about the Twist Gear is that installed with OEM primary and secondary gearing lowers the ratio in the first four gears while maintaining the final drive ratio. Or you can change go up two teeth on the motor sprocket or up two teeth on the trans drive pulley and the first four gears are very close to stock but final drive drops from 3.15 to 2.965 or 2.917 respectively. Not a huge drop in rpms, about 200 without actually doing the math which would allow say a 70mph cruise at 2700 rpms instead of 2900; round numbers of course. A 200 rpm drop might not be worth the $500 cost and the time involved to install but if no other options exist, maybe worth considering.
Travis Fish
06-07-2018 04:17 PM
kopcicle
Shovelhead
10-22-2012 05:46 PM
CurtisP
08-27-2012 08:18 AM
rfranz1952
03-12-2008 04:13 PM
Spitshine
Shovelhead
01-14-2008 02:31 PM
Quick Reply: 5 speed evo over drive?
