Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Quick clutch question
Old Jul 31, 2019 | 01:39 PM
Drnapalm's Avatar
Drnapalm
1st Gear
Default Quick clutch question
My sportster seems to lug slightly when the clutch is disengaged and moves when it’s engaged. I’ve adjusted clutch to no avail of symptoms. It also has issues when shifting up or down in any gear. Am I correct in my assumption that the clutch is gone? I have heard of the clutch spring grenading, and my shift shaft lever seems a bit loose, wondering if these are related.
Old Jul 31, 2019 | 04:54 PM
Sorce's Avatar
Sorce
For how long?
What happened that made this happen?
Did you adjust behind the derby cover as well?
How's the oil level?
Sorce
Old Jul 31, 2019 | 06:04 PM
Drnapalm's Avatar
Drnapalm
1st Gear
Not too long, it seems it’s been getting progressively worse, I’ve just really been aware of it now because I’ve been having issues shifting more frequently. Non specific to any Up/down, gear selection. The oil level has been fine, I’ve been watching it due to a shift shaft seal leak I’ve been scratching my head over completely. I’ve tried readjusting and it hasn’t seemed to make a difference. Nothing has happened that I would think would cause this, I don’t even usually ride it hard even
Old Aug 6, 2019 | 09:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sportsters have been in production since the 50`s, you need to give us more information...
What model year is the bike you are working on?
Mileage?
Engaged is when clutch lever is released, disengaged is when lever is pulled in.
Are you saying the clutch drags when it should be disengaged?
Old Aug 6, 2019 | 05:37 PM
Drnapalm's Avatar
Drnapalm
1st Gear
My bad it’s a 2004 1200 roadster. Yeah it seems to drag no matter I adjust it. It has about 24k miles. OH yeah I also meant it will pull when disengaged as well
04FordHarleyF250
Milwaukee Eight (M8)
38
Jul 6, 2019 11:14 AM
dhinson907
Jul 7, 2015 06:25 PM
hall1836
Dec 2, 2012 04:01 PM
lou1
May 19, 2008 03:00 PM
rayhdavidson
Mar 2, 2007 03:55 PM
