tight drive belt
RE: tight drive belt
As the sprockets heat up they expand pulling the belt tight in the process. Same thing happens with the primary chain. The slack settings are done cold to provide a not too tight condition when hot. Obviously following this logic through and things being temperature sensitive I try to set slacks in around the 70 degree mark. This will cover the colder days that you would ride and the hotter days. It's a compromise that seems to work well enough. If yours is whining when hot, it may not have enough slack when cold and gets too tight when it heats up.
Ron
Ron
ORIGINAL: bigthump
Does anyone know why theFLHX drive belt is tighter than the otherFLH?
