Neutral between 3 and 4 gear
My bike is a 98 dyna lowrider. I had rebuilt the transmission because I was getting neutral between 3 and 4 gear. I used a Baker rebuild kit, N-1 shift drum and their shift pawl. That was about a year ago. Problem is it still has the same issue.
I have to purposefully shift from 3 to 4 to avoid the neutral, sometimes when I forget and hit neutral and let off the gas, it goes into 5 by itself, all other gears shift nice. The shift forks are stock and were checked with a straight edge for flatness and the gears looked ok to me.
According to the power flow chart in the FSM 4 gear is 1 and 4 mainshaft gears locked together to make 4 gear. I was thinking maybe 1 gear dogs or the 4 gear slots they engage in are worn out causing this. I can't figure this one out. To anybody that knows the 5 speed, whats your take on this? Any advice would be much appreciated, Thanks.
The baker shift arm should have corrected over-shift. It did for my 2000 FXDX. What Dan says is a possibility. Rounded dogs could cause over shift. I would check shift pawl adjustment first. The trick is to look at the pawl clearance while up shifting and down shifting. With the rear wheel off the ground. shift from 3rd to 4th but keep holding up on the lever. Lift the pawl up and look at the clearance between the pawl claw and the pin. Do the same down shifting from 4th to 3rd. They should be the same. Also make sure the shift pawl pin in the right location. It can be adjusted one of 2 ways.
corliss@bakerdrivetrain.com (05-12-2020)
Ccr71
04-11-2017 04:29 PM
