2005 Road King Acceleration/slipping Issue
2005 Road king feels like clutch slipping when accelerating in low gears. Installed new clutch, properly adjusted, definitely not the clutch. Changed the belt a few Months ago and the tension is still perfect. Chain tension seems perfect. All 3 holes changed and is the same oil I've been using for 25,000 miles 20W 50 and no chips found. Bike has 45,000 miles. I'm baffled thinking maybe a spline issue with the chain drive or clutch spline, but it does shift/ride smooth. Can the belt slip even when its correctly tightened?? Thanks
Any engine mods that might be overpowering the stock clutch?
A slipping clutch will turn primary fluid dark pretty quickly.
New clutch springs are pretty cheap and easy to swap
You say it otherwise runs fine
Stripped splines or belt would probably have put you on the side of the road waiting for tow I would think
M Oclaf (10-03-2022)
1. does it slip in higher gears?
2. When is slips do you hear / feel a grinding?
3. What clutch kit did you use?
Generally if some thing like a chain, belt or comp slip, thet make a grinding sound. Stripped splines generally simply pop.
