Aftermarket 6 speed transmission (Baker, Ultima, etc.)
Hi all,
I just picked up a project bike in pieces that has a RHD 6 speed transmission. It has a barbed fitting at the top of the left side, right behind the shifter arm. What is this for? Is it a breather? can't find any info anywhere. Was going to call manufacturer but think it is some Korean brand and people here are probably more knowledgeable anyway.
Thanks
Thanks
Hi all,
Thanks
Thanks
Ultima is very very good products. People really put them down and most of the negative reviews and issues are from early production parts, not current.
I’ve blue printed and assembled several engines now both Shovel and EVO. One a few years back with basic port work, and a good D carb made more than the advertised power with drag pipes. My personal 127 I put together has not been ported, running a bored out G, have not Dyno’d it yet but I’m positive I’ll get the advertised numbers.
I’m running the 6 speed, zero issues at first and then I got some false neutrals between gears.. simple adjustment and it’s good. It shifts smoothly and feels good. Running chain and 47T rear gear, I can easily lift the front wheel in the first three gears.
Don’t be so hard on Ultima it’s a very good value. They are American made no matter what others say. They do farm out some parts here and there, but by and large it’s every bit as American made as S&S. I actually prefer their crank and Rods to S&S. If you cherry pick all the manufacturers for their best value and performance blend Ultima is right there with the best. I like S&S Rockers, lifter, pushrods.. but prefer Ultima cases, cranks, rods and Heads..
Thanks for quick response,
I don't believe my transmission is a Ultima. I can't find any numbers or markings on it, but it looks like a typical Ultima or Baker. That why I assumed it was an overseas reproduction product. I have used Ultima products before and have had no issues. Thanks for the clarification on the fitting.
Welcome Pascal.
Hope you continue to enjoy your ride here with us on the HDFORUM.
Only as a suggestion, but very important, create a signature line similar to mine on your bike with the year, model, and all the letters Harley assigned to the bike. It will appear at the bottom of your post.
You can also add a favorite picture to the signature line.
Doing this will be helpful if you ask a question or to someone asking a question. All Harleys aren't the same with many changes and variations over the years.
You can also add a favorite picture for an Aviator postage stamp you see at the top left of your post.
Received 8,259 Likes
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
corliss@bakerdrivetrain.com
Vendor For Sale Classifieds
07-29-2017 11:50 AM
