Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
2016 Ultra Limited
Old Feb 9, 2026 | 04:17 PM
2011BlackGlide's Avatar
2011BlackGlide
Default 2016 Ultra Limited
Anyone have an idea what an independent Harley shop would charge to replace primary bearing? What’s the skill level required to do it? Could I do it myself?
Old Feb 9, 2026 | 09:01 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Probably looking at 4 hours labor and whatever labor costs are for your local area plus the parts.. You're looking at at least $180 in gaskets, seals and bearing.. You can do it if you have the proper tools the hardest part is getting the clutch properly adjusted after installation and pressing out and in the new bearing.. A Factory Service Manual is essential..
Old Feb 10, 2026 | 01:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How do you know it is the inner primary bearing?
Old Feb 11, 2026 | 10:31 AM
2011BlackGlide
Hoping that is the worst case scenario. Waiting for new tensioner to arrive to install. Not sure what else to check if that doesnt quiet it down. Crank gear and primary appear to be ok.
Old Feb 11, 2026 | 03:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
To diagnose a bad inner primary bearing:
Engine running, transmission in neutral, it will make noise (the mainshaft is spinning, clutch lever position doesn`t matter).
Pull clutch lever in, drop into gear, the noise will stop (when bike is stopped, in gear, clutch disengaged, the mainshaft is not turning).
Old Feb 12, 2026 | 05:01 PM
2011BlackGlide
I put in a Hayden M6 primary chain tensioner and 80/140 synthetic gear oil. No more rattling. It’s smooth.
paulhog
Motorcycles For Sale
Aug 31, 2025 06:12 PM
camaroguy72
Apr 18, 2025 08:48 PM
user 78082023840
Mar 2, 2024 01:19 PM
josame
Mar 1, 2022 05:38 PM
Tucker99
Aug 11, 2014 10:50 AM
