Primary oil install
RE: Primary oil install
ORIGINAL: mayfiebl
Hey I just pulled the primary cover(Derby) and some fluid (Red Trans like) What oil? and Its been a while since I had a closed primary...Where do you put the oil in??? I know the engine oil and the trans but the Primary?
http://www.expertvillage.com/intervi...aintenance.htm
Sometime down the road I'm going to drill and tap the inner primary and add a fill hole. This is trullya retarded design . If the clutch needs adjusting I'll take the derby off. If the chain adjuster needs attention I'll pull the outer cover. Change the oil, give me a normal fill plug on the top. Wouldn't that be revolutionary?
Ron
Ron
ORIGINAL: rbabos
Ron
Ron
ORIGINAL: rbabos
Ron
Ron
http://www.corbin.com/accessories/ezpour.shtml
ORIGINAL: mayfiebl
So Mine is a 92 your saying crack that Primary cover(Durby) and poor in How would I know when its enough???
