Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
final drive belt noise
Old Sep 30, 2008 | 11:39 AM
pittguy's Avatar
pittguy
If the belt was shiney on the side,chances are it wasnt aligned well enough.Yes a rock can damage the belt,even easier when real tight,sometimes pulley will also show the wear.I still feel the tension on a FLHX is too tight,running at the other tourer tensions has worked fine on mine.
Old Oct 1, 2008 | 03:33 AM
pauly_2's Avatar
pauly_2
Default Belt drive noise
Hey Bogie,
Have you tried adjusting the right hand adjustment belt just a little bit inwards (in other words, aligning the rear wheel (just a tiny bit) counterclockwise? You mention the outside of the belt is shiny which may indicate there's a touch too much contact between the belt and the outside of the pulley - hence the noise.
It'd be great if that fixed it! :-)
Pauly_2
Old Oct 1, 2008 | 08:33 AM
pmcburne's Avatar
pmcburne
Default belt whine
try loosening it a bit just like the other guys have mentioned and apply a light smear of silicone grease to the edges of the belt
Old Mar 4, 2022 | 03:35 AM
racerfranz's Avatar
racerfranz
I know this is an old old post, but it makes me crazy that there is no follow up as what ultimately worked...
Old Mar 23, 2022 | 08:56 AM
ADKRider's Avatar
ADKRider
My 2021 Heritage has had belt noise since new. It's a rhythmic rub that has yet to be cured. The dealership has checked alignment, changed tires, and has yet to cure it. They ultimately told me that a number of softails make this noise, that it is not dangerous, and I shouldn't worry
(information supposedly from the factory rep). I don't buy it. It's been at the dealership over the winter. I'm going there in a few minutes to see what we can do next before I pick it up for the riding season. I'd appreciate any further recommendations from the forum members.
Thanks.
TEEBAR
Apr 26, 2013 06:21 PM
WRAITH
Nov 1, 2007 12:06 PM
MixedNuts
Jun 18, 2006 10:56 PM
tankr
General Topics/Tech Tips
Apr 23, 2006 01:04 AM
bluedog
Feb 23, 2006 12:15 PM
