Belt noise
Old Apr 26, 2013 | 12:16 PM
TEEBAR's Avatar
TEEBAR
Stage II
Default Belt noise
My 05 deluxe seems to have some type of belt noise,wineing sound from lt front
floor board area.I was advised that the belt was to tight,so i loosened the belt
tention.After that the wineing noise went away,now upon rideing during throttle there is no noise until i let of the throttle,the belt seems like it is rubbing and a warping kind of sound.Any suggestions greatly appreciated*****teebar
Old Apr 26, 2013 | 04:20 PM
jreichart's Avatar
jreichart
I assume you realigned the wheel/belt when you lossened the tension?
Old Apr 26, 2013 | 04:26 PM
ynots's Avatar
ynots
And the belt should have the proper deflection with the riders weight on the bike. Having a over tightened drive belt can cause a lot of problems
Edit:
Oop's, Your talking about a belt driven primary?
Old Apr 26, 2013 | 04:28 PM
Harleycruiser's Avatar
Harleycruiser
Yep like he said, check the alignment, also make sure you use a gauge to adjust the tension, unless you have done this many time, this is nothing to guess at.
How many miles, do you ride on sand roads a lot, the belt, pulleys might be wore out.
Old Apr 26, 2013 | 04:42 PM
Jackie Paper's Avatar
Jackie Paper
Get you a gage. Good one on Amazon. Set your tension like it says for your bike. Forget the twist and other expert ways. That belt and pulleys and the trouble to change it is crazy high. Softail needs a helper or like I do it lying across seat to do check. Be sure rear wheel is aligned to engine so belt tracks correctly Normal is light pressure to out side flange rotating tire as it drives. You have 1/32 tolerance to swingarm bearing centerlines. Softails align mainly to engine / transmission. All OK?, your belt may be too clean. Dust it with a little talcum. The sound if it's your belt will go away.
Old Apr 26, 2013 | 06:21 PM
wils5150's Avatar
wils5150
is your bike lowered?
bogie
14
Mar 23, 2022 08:56 AM
Jazzhog
Jun 27, 2011 01:41 PM
MixedNuts
Jun 18, 2006 10:56 PM
tankr
General Topics/Tech Tips
Apr 23, 2006 01:04 AM
bluedog
Feb 23, 2006 12:15 PM
