Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1996 Shifter shaft replacement
Old 10-25-2008, 01:36 PM
CurlMan's Avatar
CurlMan
CurlMan is offline
Default 1996 Shifter shaft replacement
My 96 FLHTC has developed some side to side wobble on the rear (transmission end) shifter bracket. I attempted to loosen and re tighten the shifter arm bracket but there seems to be some pretty bad wear on the splined shifter shaft. I know I'll have to pull the inner primary to get to the shaft and the tranny. Has anyone dealt with this issue before? I'm planning to replace the shifter shaft from the tranny as a winter project.
Any info is appreciated.
hhiii
04-02-2019 09:37 AM
PFR-Captain
06-05-2014 02:27 PM
MichiganRider
12-24-2012 04:43 PM
zubaugh
04-26-2008 01:25 PM
MoesSS
02-10-2006 08:07 AM
Quick Reply: 1996 Shifter shaft replacement
