Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Double/Triple downshifting?
Old 08-25-2006, 08:29 PM
Lutty's Avatar
Lutty
Lutty is offline
Default Double/Triple downshifting?
Does it do any damage to the transmission to double or triple downshift (or upshift) while holding in the clutch? I find that when I am approaching a stop sign that it is easier sometimes to quickly downshift into first with one clutch pull than to go through all the gears letting the clutch out each time.
Thanks!
Old 08-25-2006, 08:48 PM
turbo54's Avatar
turbo54
turbo54 is offline
Default RE: Double/Triple downshifting?
I do it all the time drop into 3 rd what evey. Even lug the dog out of her. I don,t know. I know the engine is tough as hell. 2000 95 cc RG203 cams pc 3 dino tune 42 mm thr0ttle body thunder header with 57 k on her,Soon to have the 510 cams and gear drive.
[IMG]local://upfiles/3159/746ED33E496D44BAAE24B64F35AB595C.jpg[/IMG]
Old 08-25-2006, 11:27 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
One_Screamin_Eagle is offline
None at all, but sometimes they won't shift after a couple in a row and you have to blip the throttle or let the clutch out slightly
Old 08-26-2006, 02:35 AM
mp's Avatar
mp
mp is offline
Doesn't damage the clutch, but it can damage the transmission or the engine if you are down in first at too high a road speed and suddenly have to engage the clutch for whatever reason. It's also easier on the brakes if you downshift a gear at a time and let the engine compression do some of the braking. It's just plain smarter to go down a gear at a time, because of the ratcheting shifter that motorcycles have, and be ready in case a sudden change in braking or acceleration is needed.
Old 08-31-2006, 04:54 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 22,032 Likes on 8,470 Posts
While on the topic of coasting, you might want to be aware that the tranny isn't getting as much oil circulated when coasting as it should have at the speed you are traveling. This is more of a caution for when your decending a long hill.
slvrscoobie
06-27-2016 04:51 AM
clap
08-30-2013 08:51 PM
gdeese
07-24-2010 09:07 AM
fiveola
Shovelhead
05-18-2008 01:48 PM
1200c
08-22-2005 12:56 AM
Quick Reply: Double/Triple downshifting?
