Stupid Question
Old Aug 29, 2013 | 10:41 PM
clap's Avatar
clap
Default Stupid Question
I noticed that with the clutch lever pulled in and bike in gear the bike is hard to move. But with the engine running and in gear and lever pulled in it just sits there like it should. Is this something normal that I never noticed or is there something wrong with the clutch. It does jump a little if you start it in gear with the lever pulled though but not real bad.
Thanks Clap
Old Aug 29, 2013 | 11:42 PM
Def Mute's Avatar
Def Mute
That's normal...
If you're going to move the bike manually, usually best to put it in neutral. Starting, you're probably going to be in gear shortly, so it's not as much of a nuisance.
Old Aug 29, 2013 | 11:43 PM
Bluehighways's Avatar
Bluehighways
On a Multiplate Wet Clutch such as our Harley's have, there is always a bit of drag even with the Clutch Lever pulled in (clutch released). Even more so when the oil is cold.
With the Engine off when you try and push the bike, with the bike in gear one set of the Clutch Plates are held stationary by the Engine (which is stopped) while you're trying to rotate the Clutch Plates that are attached to the Transmission Input Shaft because the Transmission is in Gear. The effort you feel is the drag between the Clutch Plates multiplied by the gear ratio of whatever gear you've got the Transmission in, plus the ratio of the Drive Belt (or chain). Take it out of gear and all you're trying to turn is the Transmission Output Shaft. With the Transmission in Neutral you're no longer trying to turn the Transmission Input Shaft when you rotate the Output Shaft. Since you're no longer rotating the Input Shaft with the Transmission in Neutral, you no longer have the drag of the Clutch to contend with.
The opposite takes place when you first put the Transmission in gear and you get a fairly solid thwack at the engagement of the gear, even with the Clutch disengaged. This is because the aforementioned drag of the Clutch is in fact causing the Input Shaft of the transmission to rotate (even with the Clutch Lever pulled in) while the Transmission Output Shaft is stationary, because the rear wheel isn't moving. When you engage a gear (hopefully 1st gear) this brings the Clutch Plates that are attached to the Transmission Input Shaft to a very rapid halt . . . hence the Thwack.
Old Aug 30, 2013 | 06:36 AM
Geezr Glidr's Avatar
Geezr Glidr
Good to know. Sometimes I get to that parking spot where it's J U S T a little too much to back that Ultra up. I'll try it in neutral. Thanks.
Old Aug 30, 2013 | 07:01 AM
Buckinfitch's Avatar
Buckinfitch
Thanks Clap
wasn't a stupid question... the answer was very informative. thx bh
Old Aug 30, 2013 | 08:01 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I started my in gear once and that was enough for me. I'll never do it again. That drag and lurch crap sucked.
Old Aug 30, 2013 | 08:28 AM
cayers's Avatar
cayers
Very informative response, thanks!
Old Aug 30, 2013 | 11:16 AM
Coastal CVO's Avatar
Coastal CVO
Another factoid, oil viscosity is a contributor, oil tends to be sticky-er when cold.
Even dry clutch's will have drag.
Old Aug 30, 2013 | 12:00 PM
AnotherBlackSG's Avatar
AnotherBlackSG
Absolutely!
Old Aug 30, 2013 | 08:51 PM
CajunGlide03's Avatar
CajunGlide03
Thumbs up
Originally Posted by AnotherBlackSG
Absolutely!
Agree. Good info for those of us who are technically challenged...
BuzzCap7
17
May 6, 2017 09:21 AM
TheGit12
Nov 1, 2015 04:45 PM
D-BOY
Nov 7, 2014 03:08 PM
Springermoneypit
Mar 27, 2012 01:10 PM
fiveola
Shovelhead
May 18, 2008 01:48 PM
