Clutch Won't Engage
Clutch Won't Engage
Hey guys,
Need some help here before I set my first ever bike ablaze....2000 Heritage Softail Classic...replaced stator. Now that it's all back together, the bike will shift out of nuetral into first but will not move. In other words, pull the clutch lever on the handle in, shift into first from nuetral, and release the clutch slowly while giving it some gas....and the bike doesn't move. I would really really appreaciate any suggestions or ideas.
Thanks in advance.
Thanks in advance.
Do another clutch adjustment by the book. Collapse the cable, pull lever in, then set clutch with 1/2-1 turn out. Make sure it doesn' change whie you tighten the locknut.
If you mean the ball bearing, I say no because you would need to remove that sde cover and remove the circlip that hlds the ramps in place. I doubt the OP removd that cover to do a stator.
