Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I have a 1983 fxsb the pulley wobbles when its tight and leaks oil does the main shaft use a bushing or a bearing and will replacing this fix the problem Thanks
Ride free Die fast
I would bet some donuts that it is the bushing under the output drive gear. When that wears it seeps oil through the small seal and the output drive sprocket or pulley will wobble. Trans needs to come out and needs main shaft rebuilt.
