Ride-On tire sealant
I put the Ride-on tire sealant in my tires today. I put it in a RKC with spoke wheels, inner tubes and Metzler tires with about 4k miles on them. I had ordered it a few weeks ago when it was being discussed on the forum.
https://www.hdforums.com/m_1116307/tm.htm
It's easy to install although I did go to the Hardware store and by a longer length of tubing .29 cents, to make it easier to get it through the spokes. The first few miles it felt like my tires had a flat spot, but that smoothed out after about 4 miles.
The only real test is to see if I get a puncture which is sealed by the product. I'd just as soon that didn't happen. I will be happy if it prevents leakage of air from the tires and acts as a tire balancer. Will post back if anything happens with the product.
http://www.ride-onshop.com/Products-Motorcycles.html
RE: Ride-On tire sealant
I have been thinking about the same thing for the spoke wheels on my Hertiage Classic. I di not realize this could be used on the spoke tires. Keep us posted. Do the original dulops that come on the spoked Hertiage Classic have tubes? I always get this confused. Do all spoked wheels have tubes?
Thank You in advance
I hadn't heard of this product, but would be very interested to hear how it performs as i have an 06 Bob w/spoked wheels and have already experienced my 1st flat...and tow...less than a month from being new.Had always heard that the fix-a-flat type stuff would not work on tubes...and to my knowledge, all spoked wheels have tube tires.
My friend has used ride-on in his Goldwing. I am unaware of him having a flat, but he does state that the bike tends to ride smoother.
I believe that on the bottle, it says it is noncorrosive. However, some ride-on was accidentally spilled on a painted steel table in my shop. I decided to leave it there just for the heck of it.Aboutamonth later and it took the paint off and it is now rusting there.
Imagine what it can do in a wheel...Screw that!!
Haven't been able to ride since I put it in. I should ride tomorrow and see what I see. I think I'll try the paint test myself on something to see how it goes. It's water soluble and cleans up easily. With my spokes it doesn't matter much as it's contained in the tube. If it prevents a blowout it pays for itself.
Sorry guys, Yes I did get a ride in last week for about 120 miles. Bike rode smoothly, the tires felt like they wanted to follow every road groove but that was most likely an inflation issue. I will check the end of this week to see if the tire retains air better, if not I am going to replace the valve stem inserts as they had slight corrosion around the base when i pulled them to put in the sealer. One of the claims of the product is to lengthen the life of the tire by preventing underinflation due to less air loss through the valve.
Since the claim is to be able to seal a 1/8 inch hole in a tube tire I would love to intentionally puncture a tire that is due for replacement and see if it seals up. Unfortunatly for this purpose, my tires have quite a bit of life left in them.
