CVO tour pack turn signal harness conversion question
Hi,anybody know what harness to use to make tour pak LED bar corners to work as turn sigs?? Seen them work on other bikes but not sure what parts to convert. Hd or aftermarket?? Thanks
Hmm interesting. Can you take pic of rear fender harness connector? I wanna see if they did y harness off there for sigs. My box light is run/brake only. Seems like would have to come off fender harness to have sigs there too.
76 yo and don't even own a smart phone - pictures??
I just went out, looked and here's what it has - in addition to the under pak amplifier & cable assy it has two antenna wires, one each side,
going into the bottom of the pak along with two small cable assy on the bottom right and one small cable assy going in on the bottom left. My
tour pak has both speakers and passenger audio controls on each side along with a 12v outlet inside. This is the picture you'll get from me lmao.
Hell, we only use the clock on the radio and still haven't changed to daylight savings yet. Fwiw I can see nothing coming up from my rear lights
as they are fed via a cable that goes through a hole in the top of the rear fender so it's split off further ahead.
I bought everything but the electrical connectors to make my tourpak a quick disconnect but after looking everything over I've just left it alone.
