Custom Dynamics Brake Light Flasher
sportglide (02-11-2018)
I put a Bright *** Light on mine...mainly because I had one I kept off my trade in. 20+ patterns. I did install the Custom Dynamics flash module for the tour pack lights. Simple install. 9 or 10 patterns including “do nothing”. If they work the same way, the unit has a rotary switch you use to select what pattern you want to use.
PistolPete83 (02-14-2018)
I installed CD brake light flasher on my 18 Ultra Limited Low. It has 10 flashing settings. You can select the settings by turning the small ****. If you have a small screwdriver works better. (there is a slot.) To turn it off you would have to disconnect it. I set mine at 4 flashes and then steady. (the lowest setting) I want to be seen, not annoying. Also installed LED tail lights
Thanks for the responses. My only concern was this statement on Custom Dynamics website. "Utilize the more rapid strobe patterns by upgrading the center taillight to a Custom Dynamics® LED Squareback or Laydown rear center taillight." Just wanter to make sure all of the strobe patterns worked on the CVO OEM brake light.
