2013 cvo ultra
2013 cvo ultra
I recently changed the engine oil and filter. I fired the bike up and now I hear a whining or wuring sound come form the primary case side. is this sound normal? At idle no noise, rev it and the noise is there. this is a screaming eagle 110 motor with 25000 miles on her. any info is greatly appreciated!!!! bikerbill71
2013 cvo ultra whining sound from primary case side
Morning, the chain tensioner wasn't tight and no I did not drain the primary when I changed the oil. I believe I found the whining sound, the bearing on the inner primary case for the clutch shaft is worn. Does anybody have the torq specs for the inner primary bolts, the compensator sprocket bolt, the clutch basket nut and the chain tensioner bolts?? I have a supplement service manual but the manual doesn't show the torq specs. Would like to get her up and running for the weekend.
