Wheel bearing end play
Old 04-25-2017, 10:51 AM
Meatpants's Avatar
Meatpants
Meatpants is offline
Default Wheel bearing end play
Not too familiar with tapered bearing in wheels, I think the PO of my bike had thrown in some new bearings but didn't bother checking end play afterwards, the rear wheel seems ok, but might be a little snug, so I'll have to add some shims, the front wheel has TONS of play so I'll have to, from what I understand, remove some material on the lathe since there are no shims installed.
For the rear, what kind of shims do I need to use? I can't seem to find part numbers anywhere.
Old 04-26-2017, 11:56 AM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,199 Likes on 1,274 Posts
There is a shim kit you can order from HD. I've seen it in the parts book but don't have it handy right now.
carl
Old 04-26-2017, 01:39 PM
Meatpants's Avatar
Meatpants
Default update
I see when you are shimming the inner spacer in the wheel that you are supposed to use a stepped shim so that it mates against the bearing. The ones I find are 43650-82, but all the sites I try and order it from tell me it doesn't fit on my bike. I'm confused ha, I miss sealed bearings.
sbrmike
Wheels/Tires
03-09-2018 04:20 PM
cike
10-15-2017 06:01 PM
jerryboy
05-17-2017 07:27 PM
DrifterD
Wheels/Tires
12-22-2015 09:53 PM
arnold
11-23-2010 06:33 PM
Quick Reply: Wheel bearing end play
