74 FXE circuit breakers
Old May 10, 2017 | 03:23 PM
1Fordman's Avatar
1Fordman
Default 74 FXE circuit breakers
Need to know the amps rating on the circuit breaker that attaches to the battery and the 3 attached to the rear fender. I'm making a 72 FX kick start into a 73 FXE, so a bit of rewiring is coming up!
Old May 10, 2017 | 08:28 PM
johnjzjz's Avatar
johnjzjz
you could omit the fender circuit brakers by using one 30 amp on the battery but it does get busy on the feeder line on a machine that has lots of stuff
30 amp is a go to for the battery what ever you do - the others are always 15 amp and today we use the sealed plastic one's rather then the metal
Old May 10, 2017 | 11:53 PM
panz4ever's Avatar
panz4ever
15 amp breakers are mounted on the rear fender...
Starter relay mounted here...
30 amp breaker runs off the + side of the battery terminal
Old May 11, 2017 | 09:41 PM
1Fordman's Avatar
1Fordman
Thank you for the photos, shows exactly where they need to be. I'm going to use a 5 terminal Bosch relay for the starter. The bikes a 72 FX (originally kick only) but somewhere in it's life it got electrified. But Bubba did the wiring, and what a mess.
Got a 74 FXE wiring harness and will be done right upon reassembly.
Saun
Shovelhead
Feb 11, 2018 06:28 PM
SgtMic
Audio Systems
Feb 10, 2017 06:26 PM
wils5150
Audio Systems
Aug 21, 2016 07:12 AM
remerson
Audio Systems
Mar 27, 2014 11:05 AM
Born2cure
May 26, 2009 07:45 AM
