1979 flh 1200 shutting down
08-30-2017, 07:12 PM
Bike shuts down after riding about 1 hr but still has spark and after about a few minutes fires back up any suggestions
08-30-2017, 08:26 PM
Check gas cap vent and if split tanks
Look at your gas cap make sure vent open and if have split tanks check crossover line a good luck.
08-30-2017, 08:53 PM
really not enough info - what ignition - is it original in its wiring - carb type - had trouble in the past with gas tank - kind of thing
08-30-2017, 11:14 PM
First thought with limited info...bad coil
08-31-2017, 04:59 PM
Originally Posted by
panz4ever
Pretty good bet its the coil. Fails when it gets hot and works again when it cools down. Been through that scenario a couple of times over the years.
09-02-2017, 02:13 PM
My ironhead was doing the same. Ran ok then after it got hot it would die out. Wouldn't restart till after it cooled off. It was the coil going out.
i used the coil as an excuse to buy an ultima ignition with a new coil and the thing has run like new machine ever since
beckreit
Shovelhead
11-30-2017 01:59 PM
Bobcat94564
Shovelhead
09-24-2017 05:22 PM
RShaips
Shovelhead
03-17-2010 12:21 AM
billo
09-30-2009 09:14 AM
alwayswrenchingmyhog
05-11-2007 01:27 PM
