83 Fxsb starter gear bouncing around
Received 3,222 Likes
K...in order for the starter to engage the clutch hub properly, the outer primary needs to attached. There is a copper washer that goes on the end before you put the cover on as well.
When you hit the starter button the elcetrical system activates the solenoid which activates the bendix gear pushing it out over your clutch hub. The end of the gear is driven into the end of your outer cover (there is a needle bearing in the cover). With the outer primary cover on there is no "bouncing", just a straight push.
You are lost...and cannot be found!!!
Never heard of anyone trying to operate starter with shaft running wild!!!
The following 4 users liked this post by Redrodyankneck:
