PanShovelution build
07-17-2019, 10:06 AM
I will start it with Electric Start, but it does not have any impediment to start it with a kick, just the biggest compression. I will use an electronic ignition, I take the S & S adapter to cone style.
07-17-2019, 02:35 PM
Good looking motor! I suppose it's too late to install compression releases?
07-17-2019, 05:05 PM
Quote:
Originally Posted by
Joe12RK
he has 4 plugs that do actually nothing but give you a location for compression releases
07-17-2019, 06:43 PM
will that fit back in the frame. height wise
07-17-2019, 07:11 PM
I see a 151 inch motor start with 10.8 to 1 with a ekectric starter......no compression releases. My 140 i put manual ones But i would be willng to bet one of my home bilt starters will start it using correct battery...
07-17-2019, 11:47 PM
Joe12RK
I have the right spark plug holes. This bathtub combustion chambers don't need dual spark plug.
john lee
It's only a millimeter longer than a Shovel. By using short pistons I have reduced the height 5mm.
mud
03-06-2020 10:29 AM
Shootermwc
Custom Models
28
11-11-2019 10:23 AM
breakout18
Shovelhead
07-01-2019 09:44 AM
PhilM
08-02-2010 03:29 PM
WhiteGoldSG
03-04-2010 11:31 PM
