1983 FXDG Disc Glide Rebuild/Restore
  #71
Old 03-20-2019, 08:35 AM
pjb's Avatar
pjb
pjb is online now
It's been many years since I removed the turn signals from my FXWG. Now, I'm putting them back on. Can anyone remind me of the wire routing along the fender strut?
I know where to plug them in on the junction block.
  #72
Old 03-20-2019, 09:31 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,426 Likes on 885 Posts
IDK about your particular fender, but they usually go inside it, in a metal tray like area
  #73
Old 03-20-2019, 09:40 AM
pjb's Avatar
pjb
pjb is online now
Pretty sure the wire runs between the strut and the fender, and comes out near where the strut bolts to the frame. Then the junction block is right there mounted to the fender.
I haven't tried it yet, I'm sure it's simple.
  #74
Old 04-01-2019, 09:26 AM
shovhd's Avatar
shovhd
shovhd is offline
Default Beltguard Support Arm
I want to remove the support arm for paint and to replace the rubber washers. Is there a trick or am I just drilling it out and replacing with a bolt?
  #75
Old 04-01-2019, 10:26 AM
troy montoya's Avatar
troy montoya
troy montoya is offline
Hi Shovhd, when i did mine i just drilled out the rivet & put a 1/4" bolt with an acorn nut to secure the support arm back on the belt guard again
belt guard with bolt & acorn nut
  #76
Old 06-22-2019, 02:58 AM
troy montoya
Default She's Done ,Almost ! 1rst 100 miles test drive !
The following 2 users liked this post by troy montoya:
Architect (06-26-2019), nzhog (08-09-2019)
  #77
Old 06-22-2019, 03:10 AM
troy montoya
Hi Every body Yes She's almost done ,the belt guard is at the Paint shop clear coat, had her on the Road for week now & got the first 100 miles on her , really glad to have this project complete , thanks to MrLexus, Shovhd, & FXDG-Randy, without your help it would not have turned out as well as it has !
  #78
Old 06-22-2019, 09:46 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
nice job, it came out great! enjoy riding it
  #79
Old 06-25-2019, 09:13 AM
pjb's Avatar
pjb
pjb is online now
What kind of tag bracket is that? Never seen one that huge.
  #80
Old 06-25-2019, 09:40 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,056 Likes on 1,511 Posts
Originally Posted by pjb
what kind of tag bracket is that? Never seen one that huge.
eu... !
Quick Reply: 1983 FXDG Disc Glide Rebuild/Restore
