Wiring harness pin thingies in headlight?
Thanks, everyone for the info. It sounds like I was on the right track with my plan to replace pins and re-use connector blocks. I found the new pins (male and female) on e-bay, and a crimper tool made for them. I have service manual and Haynes with wiring diagrams that I've used extensively. I will come up with a system to make sure everything goes back to the right location. The reason I want to stick with the hard-to-find (and harder to remove) pins is that they really are efficient space-wise and I wasn't comfortable with installing a new wire harness and cramming a bunch of AutoZone spade clips or something in to the headlight housing. Onward!
Received 3,222 Likes
Help with 12 pin molex connector Picture of the back of the molex with wire's still in the holes..
I'm in the same boat with ya! I'm planning on using proper connectors when it goes back together. I'm an electrician by trade and usually use 3M connectors, that's what i was planning on. If we could get some of the more knowledgeable guys here to chime in for us and let us know the 'does and don'ts' that would be great.
This is the back of the plug going into the headlight I don't know what colors these wires are and I don't know where the blinkers go on this back of this plug can somebody give me a hand and tell me where they go or send a picture of the colors. 1988 1200 Sportster, thank you.
They been cut ,not by myself got it this way and and stumped.. I have a hard time reading electric diagrams so any help would be appreciated 👍..
khansmith
09-01-2007 06:55 AM
Reckless Kelly
04-09-2007 03:20 PM
