75 FLH Mainshaft Bearing Support
Old 06-13-2019, 07:27 AM
tom13's Avatar
tom13
tom13 is offline
Default 75 FLH Mainshaft Bearing Support
Pulled my transmission to install the speedometer drive gear. Someone had obviously been in there before. During the removal, I noticed that there wasn't a mainshaft bearing support plate. My question is were there some 4 speed transmissions of the ratchet top variety made that didn't require it? There are some standoff ears cast into the transmission case and from using my calibrated eyeball, there isn't any room to install the bearing support. Thanks.
Old 06-13-2019, 08:19 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,055 Likes on 1,511 Posts
??? The Inner primary is the mainshaft support [and Bearing] on an FLH
Got me confused what yer workin on.... FLH???
Old 06-13-2019, 09:08 AM
tom13's Avatar
tom13
tom13 is offline
Racepres, thanks for your response. FLH, my bad. Got it a couple of years ago as a basket case. What got me wondering is when I was ordering parts, the vendor sells a mainshaft bearing support plate. The case is painted black and I didn't see a seam, so I figured I was good to go, just needed some verification before I reinstall everything.
Old 06-13-2019, 09:15 AM
Racepres's Avatar
Racepres
Racepres is offline
Everyone has those available... for folks Not running an Inner Primary..
I do Advocate a new primary Support bearing... and if not a Sealed Primary... I use a sealed Bearing...
75FLHScott (06-15-2019)
Old 06-13-2019, 10:38 AM
tom13's Avatar
tom13
tom13 is offline
That explains everything. Didn't occur to me that the bearing support was for not running an inner primary.
Old 06-13-2019, 11:20 AM
Bumpandrun's Avatar
Bumpandrun
Bumpandrun is offline
I just happen to be doing one today ....this is the sealed bearing Racepres is talking about....I use allballls with good luck.. but others sell them. I still put the oil seal in after...probably not needed
Can’t show u installed Tom as I still have some welding to do on primary
Old 06-13-2019, 12:40 PM
tom13's Avatar
tom13
tom13 is offline
Racepres and Bumpandrun, thanks again for the education. Did run into another issue. The threads for the shift shaft retaining screw are stripped. Any idea of what size thread and pitch is? Need to retap.
Old 06-13-2019, 04:41 PM
Racepres's Avatar
Racepres
Racepres is offline
^^ I don't know what that is... do you mean the Shifter "clamp" screw??
Old 06-13-2019, 05:08 PM
tom13's Avatar
tom13
tom13 is offline
The set screw that holds the shifter fork shaft. Swung by lowes after work and sized it on their bolt size board of mystery. 1/4-24. Now to find a tap that size.
Old 06-14-2019, 01:20 PM
carlgrover's Avatar
carlgrover
carlgrover is online now
Received 2,198 Likes on 1,273 Posts
I've never heard of a 1/4-24 tap. 1/4-20 is UNC, 1/4-28 is UNF. Still, it could be that size. I have a 1/4-32 tap at home. It's the extra fine series. I believe the front master cylinder uses that size thread somewhere.
carl
Quick Reply: 75 FLH Mainshaft Bearing Support
