78 FlH Lifter Advice
Old 09-25-2019, 11:44 AM
BB.No8's Avatar
BB.No8
BB.No8 is offline
Default 78 FlH Lifter Advice
I'm going to be helping a friend of mine work on his 78 80" FLH that he said has some lifter noise. If the lifters need to be replaced what lifters would you recomend installing. I believe that the motor is fairly stock, although I know the top end has been pulled once or twice. Not sure if the lifters are orig because my friend was not the original owner (he's owned the bike since around 1990). Any advice?
Thanks
Old 09-25-2019, 11:48 AM
perki48's Avatar
perki48
perki48 is offline
Received 4,237 Likes on 1,958 Posts
First thing, see if they are solids. If so adjust them.
Old 09-25-2019, 11:56 AM
BB.No8's Avatar
BB.No8
BB.No8 is offline
Hydraulic
perki48 (09-25-2019)
Old 09-25-2019, 02:47 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,056 Likes on 1,511 Posts
Originally Posted by BB.No8
Hydraulic
I do Hydro's the hard way.... Dry.... and one at a time.. You will know at the end of this exercise if you have a bad one... either during assembly, or, certainly, After ya run it...
FLHS1990 (04-02-2024)
Old 09-25-2019, 04:05 PM
BB.No8's Avatar
BB.No8
BB.No8 is offline
OK, thanks. If we do find a bad lifter is there any particular brand of lifters that you recomend?
Old 09-25-2019, 04:38 PM
john lee's Avatar
john lee
john lee is offline
35 yrs ago i did 1 lifter replace it with a 2nd hand one from my loacal hd shop.
Old 09-25-2019, 05:57 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,588 Likes on 2,900 Posts
stock lifters can be tightened up a bit - with a long screwdriver at the base of each pushrod tube will help you id what one is the issue - then turn it down 1/2 turn more 3 nut flats - and fire it back up drive it 20 minuets and see
FLHS1990 (10-11-2023)
Old 09-25-2019, 11:18 PM
BB.No8's Avatar
BB.No8
BB.No8 is offline
Thanks John. I'll be riding up to see my buddy on Friday, I'll check it out then.
Old 09-26-2019, 03:16 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 13,952 Likes on 6,273 Posts
Got Jim's big-axle hydraulics in mine. The top end is silent.
Old 09-26-2019, 03:28 PM
BB.No8's Avatar
BB.No8
BB.No8 is offline
Thanks!
Quick Reply: 78 FlH Lifter Advice
