Starter Relay
Old 10-07-2007, 07:32 PM
SirEagle's Avatar
SirEagle
SirEagle is offline
Default Starter Relay
I want to convert my old shovel to a newer style relay, trying to find a wiring diagram of how it would be wired,,,think the smaller compact relay would look alot better
Thanks
Old 10-08-2007, 01:49 PM
custom67's Avatar
custom67
custom67 is offline
Old 10-09-2007, 11:30 PM
Shovels4ever's Avatar
Shovels4ever
Shovels4ever is offline
Default RE: Starter Relay
Try this on for size...see attached wiring diagram to wire up a late style relay:
Note: The relay will have 5 male spade connectors. They are numbered.Connect theone that says "30" to the positive side of the battery, preferrably through a 30 amp breaker; #86 to ground; #87 to starter solenoid; and, #86 to starter switch/button. Ignore the connector in the middle of the relay. Wire up the rest according to the diagram and/or your bike's wiring schematic.
Good luck.
[IMG]local://upfiles/41673/4B54124DDC2642459BADC1CA863FEB02.jpg[/IMG]
Old 10-09-2007, 11:34 PM
Shovels4ever
Sorry...that was #85 should be to starter switch/button; not #86. That single malt scotch must be kickin' mah ****!
Old 10-09-2007, 11:37 PM
Shovels4ever
Also, when you wash your bike, make sure you don't spray water directly onto the relay. Water will get in there and short out the relay, unless you've shrinked-wrap the sucka first. Sure looks a lot betta than that big bulky old-style relay!
misfitJason
EVO
22
12-23-2018 10:52 AM
novaiiman
04-14-2015 04:22 PM
Rambeaux67
EVO
02-16-2014 08:45 PM
07DYNAGLIDE
09-30-2010 05:33 PM
inthamix
Ironhead
04-07-2009 04:33 PM
Quick Reply: Starter Relay
