Speedometer drive for rear wheel??
Old Apr 8, 2009 | 08:46 PM
javalen's Avatar
javalen
Default Speedometer drive for rear wheel??
I replaced my four speed trans with a 5 speed. the 5 speed doesn't have a mechanical odometer drive so I'll have to use a snail. The problem is that on the 71 FLH there is a chrome bowl on the front tire and I don't want to mess that up so I'm wondering anyone knows if I can use a snail from the rear tire. Or if you have a solution that might work. Thanks advance.
Old Apr 9, 2009 | 07:40 AM
sqdealgeorge's Avatar
sqdealgeorge
If you decide to use the front wheel I have a new CCI unit P/N 26737 I use one on my custom FLH with a 16 in front wheel It requires 2240:60 ratio speedo Let me know
Old Apr 9, 2009 | 07:51 AM
sqdealgeorge
If you're running the stock drum brake up front forget the CCI part Back to the drawing board !
Old Apr 10, 2009 | 05:45 PM
andygears's Avatar
andygears
Default rear speedo drive
V-Twin sells a rear wheel drive kit #VT 36-0615 for the left side of '86-'95 softails. Maybe could be adapted.
andygears
Old Apr 11, 2009 | 03:54 PM
TwiZted Biker's Avatar
TwiZted Biker
Somewhere I've seen a kit for this complete with snail and extra long cable just for what you want . Do a google search bud , but the guys above said you'll probably have to change over to the later speedo .
Old Mar 5, 2023 | 04:54 PM
71shovelhead's Avatar
71shovelhead
Default Rear wheel speedo
I have that setup on my 71, problem is it won't work with a drum brake I converted mine to disc front and rear
Old Mar 5, 2023 | 05:30 PM
johnjzjz's Avatar
johnjzjz
In drags book they sell a magnetic trigger for a speedo but you will need to convert the speedo to the triggers signal
mr880
May 25, 2018 02:08 PM
Djcamis
2014-2024 Touring Models
Sep 22, 2016 06:37 AM
johnod
EVO
Aug 2, 2016 09:42 PM
rob0225
Jun 22, 2013 07:11 AM
jammer1
Jul 2, 2006 10:37 PM
