1982 FXB 'Sturgis' dry clutch question
Old 04-24-2011, 11:43 AM
shopratles's Avatar
shopratles
shopratles is offline
3rd Gear
Default 1982 FXB 'Sturgis' dry clutch question
Hey, question for clarity. 1982 FXB with a dry clutch, all original equipment, pads and steels in great shape. Clutch started slipping a few weeks ago. Checked it out and decided to add spring pressure on the basket. Harley repair manual calls for 1.032" between inner and outer plate but currently they are 1.375". Has my manual been updated because of a typo or has my clutch REALLY been that far out of adjustment all these years??? BTW, it is a 3 bolt basket.
Thanks in advance for all assistance.
Old 04-24-2011, 12:42 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,530 Likes on 5,469 Posts
1 1/32 is correct...but that only applies if you have brand new Harley parts that were manufactured in 82...The manual also says to increase the tension on the spring adjusting nuts 1/2 turn at a time till the clutch holds...do not increase tension more than it takes to make the clutch hold.
Old 05-04-2011, 02:45 PM
Horsetrader's Avatar
Horsetrader
Horsetrader is offline
That's not a big deal to pop that apart and have a look at the plates. You can scuff them up if they still have good meat on them and that will help. Sometimes they just get a little glazed up and can slip. Just remember how far in your adjuster nuts were so that you can go back to the aprox. settings and when backing out the last nut, hold the plate in so that the plate and springs don't fly off at you.
ride2tires
07-04-2012 10:29 AM
sinister1
Shovelhead
09-19-2011 01:05 PM
RidemyEVO
EVO
14
02-15-2011 01:30 PM
pistole
EVO
17
03-19-2009 12:54 AM
dragbar
05-02-2008 08:38 AM
Quick Reply: 1982 FXB 'Sturgis' dry clutch question
